240D25-17
240D25-17
$52.50 (USA and Canada only)
240 VAC, 25 Amp, DC Control Solid State Relay (SSR), Replacement Part Only
This 240 VAC, 25Amp, DC Control Solid State Relay (SSR) should be used as a replacement part only. For new development, use the equivalent 240D25 SSR instead. The two parts are manufactured identically using the same VDE-approved optocoupler and have identical specifications.
Lots of information on choosing and using SSRs can be found in the SSR data sheet. Also see the Manufacturers' part number cross-reference list. UL and CSA recognized and are a CE component, UKCA certified.
This SSR carries a lifetime warranty
NOTE: Specifications for 240D25-17 are identical to 240D25.
120/240 Volt Solid State Relays
4,000 V
Turn-on Voltage
Zero
Turn-on Time
½ cycle maximum
Turn-off Time
½ cycle maximum
Operating Frequency
25 to 65 Hz (operates at 400 Hz with six times off-state leakage)
8 pF maximum
DV/DT Off-state
200 volts per microsecond
DV/DT Commutating
Agency Approvals UL, CSA, RoHS, CE; UKCA
120D3
120D10
120D25
120D45
240D3
240D10
240D25
240D45
Nominal AC Line Voltage
120
120
120
120
240
240
240
240
Nominal Current Rating
(Amps)
3
10
25
45
3
10
25
45
1 cycle Surge (Amps) Peak
85
110
250
650
85
110
250
650
Nominal Signal Input
Resistance (Ohms)
1000
1000
1000
1000
1000
1000
1000
1000
Signal Pick-up Voltage
3VDC (32V allowed)
3VDC (32V allowed)
3VDC(32V allowed)
3VDC (32V allowed)
3VDC (32V allowed)
3VDC (32V allowed)
3VDC (32V allowed)
3VDC (32V allowed)
Signal Drop-out Voltage
1 VDC
1 VDC
1 VDC
1 VDC
1 VDC
1 VDC
1 VDC
1 VDC
Peak Repetitive Voltage
Maximum
600
600
600
600
600
600
600
600
Maximum Output
Voltage Drop
1.6 volts
1.6 volts
1.6 volts
1.6 volts
1.6 volts
1.6 volts
1.6 volts
1.6 volts
Off-State Leakage
(mA) Maximum
2.5mA
7 mA
7 mA
7 mA
5 mA
14 mA
14 mA
14 mA
Operating Voltage Range (
Volts AC)
12-140
12-140
12-140
12-140
24-280
24-280
24-280
24-280
I2t Rating t=8.3 (ms)
30
50
250
1750
30
50
250
1750
Isolation Voltage
4,000VRMS
4,000VRMS
4,000VRMS
4,000VRMS
4,000VRMS
4,000VRMS
4,000VRMS
4,000VRMS
θjc*
(°C/Watt)
11
1.3
1.2
0.67
11
1.3
1.2
0.67
Dissipation
(Watts/Amp)
1.7
1.6
1.3
0.9
1.7
1.6
1.3
0.9
Notes: θjc* = Thermal resistance junction to base. Maximum junction temperature is 110 °C.
Opto 22 SSR Overview
  • 120A10
  • 120A25
  • 240A10
  • 240A25
  • 240A45
  • 120D3
  • 120D10
  • 120D25
  • 120D45
  • 240D3
  • 240D10
  • 240Di10
  • 240D25
  • 240Di25
  • 240D30-HS [Obsolete]
  • 240D45
  • 240Di45
  • 380D25
  • 380D45
  • 480D10-12
  • 480D15-12
  • 480D25-12
  • 480D25-HS [Obsolete]
  • 480D45-12
  • 575D15-12
  • 575D45-12
  • 575D30-HS
  • 575Di45-12
  • DC60P or DC60MP
  • DC200P or DC200MP
  • DC60S-3
  • DC60S-5
  • MP120D2 or P120D2
  • MP120D4 or P120D4
  • MP240D2 or P240D2
  • MP240D4 or P240D4
  • MP380D4
  • SAFETY COVER
  • SSR-HS
  • SSR-THERMOPAD
  • Z120D10
  • Z240D10
