$48.50 (USA and Canada only)
NOTE: Specifications for 240D10-17 are identical to 240D10.
120/240 Volt Solid State Relays
4,000 V
Turn-on Voltage
Zero
Turn-on Time
½ cycle maximum
Turn-off Time
Operating Frequency
25 to 65 Hz (operates at 400 Hz with six times off-state leakage)
8 pF maximum
DV/DT Off-state
200 volts per microsecond
DV/DT Commutating
120D3
120D10
120D25
120D45
240D3
240D10
240D25
240D45
Nominal AC Line Voltage
120
240
Nominal Current Rating (Amps)
3
10
25
45
1 cycle Surge (Amps) Peak
85
110
250
650
Nominal Signal Input Resistance (Ohms)
1000
Signal Pick-up Voltage
3VDC (32V allowed)
3VDC(32V allowed)
Signal Drop-out Voltage
1 VDC
600
Maximum Output Voltage Drop
1.6 volts
Off-State Leakage (mA) Maximum
2.5mA
7 mA
5 mA
14 mA
Operating Voltage Range ( Volts AC)
12-140
24-280
I2t Rating t=8.3 (ms)
30
50
1750
Isolation Voltage
4,000VRMS
θjc* (°C/Watt)
11
1.3
1.2
0.67
Dissipation (Watts/Amp)
1.7
1.6
0.9
Notes: θjc* = Thermal resistance junction to base. Maximum junction temperature is 110 °C.
A quick overview of Opto 22 solid-state relays (SSRs).
Opto 22 provides a full range of reliable solid-state relays (SSR). This data sheet includes descriptions, specifications, dimensional drawings, and application information for these parts:
This document lists all Opto 22 part numbers that have the Canadian Standards Association (CSA) approval.
This document lists all Opto 22 part numbers that have the Underwriters Laboratory (UL) approval.
