KB89886
Published: December 14, 2023
OptoControl strategy subroutine references may not convert correctly in PAC Control Professional
All versions
When opening an OptoControl strategy with subroutines in PAC Control Professional, subroutine references may not convert correctly.
To open an OptoControl strategy with subroutines that properly convert in PAC Control Professional:
  1. Open the OptoControl strategy in PAC Control Professional.
  2. Read each prompt carefully.
  3. When prompted, create a new folder for the converted PAC Control strategy.
  4. When prompted, create a new folder for the converted subroutines. NOTE: This new subroutine folder must be a direct subfolder of the new folder used for the converted strategy in Step 3.
