$484.00 (USA and Canada only)
Feature
SNAP-TEX-MR10-4
SNAP-TEX-MR10-16
Use with I/O modules
SNAP-ODC5-i, SNAP-ODC5A-i, SNAP-ODC5SRC, SNAP-ODC-32-SRC
Use with cables
SNAP-TEX-CBO6 (odd pins bussed),SNAP-TEX-CBS6 (no bussing), or SNAP-HD-CBF6, depending on module.
Relay contacts
SPDT (1 Form C) Typical life expectancy (Electrical): 1 x 105
Switching capacity
10 A @ 240 VAC
Switch On time
7 ms nominal
Switch Off time
3 ms nominal
Fusing
24 V fuse for board. Opto 22 p/n SNAP-FUSE1AC
Indicators
4 On/Off status indicators (one for each channel) 1 fuse-blown indicator
16 On/Off status indicators (one for each channel) 1 fuse-blown indicator
Power requirements (all positions On)
24 VDC @ 75 mA
24 VDC @ 300 mA
UL, CE, RoHS, DFARS; UKCA
SNAP TEX cables and breakout boards are part of the SNAP TEX family of wiring and mounting accessories. These parts save time and expense during installation, maintenance, and debugging by reducing the time and effort required to wire field devices to SNAP I/O modules. This data sheet covers the following part numbers:
This document lists all Opto 22 part numbers that have the Underwriters Laboratory (UL) approval.
A quick overview of SNAP TEX wiring and mounting accessories.
$92.50
$96.75
$99.75
$95.00
$162.00
$452.00
$46.50
$110.00
$160.00
$451.00
$16.00
$52.00
$48.75
