SNAP-AOVA-8
SNAP-AOVA-8
$867.00 (USA and Canada only)
SNAP 8-ch analog multifunction output, voltage or current
The SNAP-AOVA-8 analog output module has 8 channels, each individually configurable for any one of six voltage or current output ranges.
Voltage:
0 to 5 VDC
0 to 10 VDC
-5 to +5 VDC
-10 to +10 VDC
Current:
4 to 20 mA
0 to 20 mA
The SNAP-AOVA-8 requires a 24 VDC excitation voltage brought in through the field connector on the top of the module. This voltage is internally isolated with transformer and digital data isolators, and then used to source all channels.
Because all current is sourced from within the module using the 24 VDC excitation, current outputs cannot be used with an external loop supply. Current outputs are self-sourcing and cannot be used in loops that are loop-powered or already have a self-sourcing device in the loop.
The SNAP-AOVA-8 mounts on a SNAP PAC rack alongside other I/O modules (digital, analog, and serial). This module requires a SNAP PAC brain or rack-mounted controller with firmware version R9.4b or higher. It cannot be used with legacy controllers or brains.
To wire the module, a 6-foot-long SNAP-HD-20F6 cable is required. The cable has a 20-pin connector at the module end and flying leads for wiring to field devices.
Excitation Range
18 TO 32 VDC
Excitation Current Required
200mA @ 32VDC, 250mA @ 24VDC, 350mA @ 18VDC
24V Excitation Fault Recovery Time
15 mS nominal
Power Requirement (from the rack)
5 VDC (±0.15) @ 150 mA
250 volts
Isolation
1500 V (transient)
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
Data Refresh Time
9 mS nom (update 1 ch/ms)
Ambient Temperature:
 Storage
-20 to 70 °C
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Wire size range
22 to 14 AWG
UL, CE, RoHS, DFARS; UKCA
Lifetime
Voltage Outputs
Output Range (Resolution)
0 to 5 VDC (1.22 mV)
0 to 10 VDC (2.44 mV)
-5 to +5 VDC (2.44 mV)
-10 to +10 VDC (4.88 mV)
Load Current
+/-10 mA min. each voltage output channel)
Short Circuit Current
16 mA Typ.
Accuracy
0.1% of span
Drift:
Gain Temperature Coefficient
Offset Temperature Coefficient
30 PPM / °C
15 PPM / °C
Current Outputs
4 to 20 mA (4 microamps)
0 to 20 mA (5 microamps)
Maximum Loop Resistance
750 Ohms (each current out­put channel )
Open Circuit Volts
27 VDC max.
(24 VDC typical)
Accuracy
0.1% of span
Drift:
30 PPM / °C
15 PPM / °C
This guide is a comprehensive introduction to the SNAP PAC System. The guide describes the system's components (software, controllers, I/O processors, and I/O); shows how to build a basic system and how to expand it; and includes installation instructions, wiring diagrams, dimensional drawings, and specifications for parts.
SNAP PAC System Product Guide
SNAP Analog Output Modules Data Sheet
SNAP I/O analog output modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for all SNAP analog output modules:
CAD 3D Drawing: SNAP-AOVA-8 Analog Output Module
This file contains a 3-dimensional CAD drawing of the SNAP-AOVA-8 analog output module. This module provides 8 channels, each individually configurable for any one of six voltage or current output ranges.
