$0.00 (USA and Canada only)
The SDK contains sample applications with source code, Windows drivers, and user documentation. It works with .NET platform languages including C#® and VB.NET®, and supports both 64-bit and 32-bit versions of:
Adapter card compatibility:
This document shows examples of system architecture for PC-based I/O control systems and lists Opto 22 products that work together for PC-based control. System examples include:
This README file lists the changes made to the Pamux Systems SDK for PCI Adapter Cards.
The PCIe-AC51 is a high-speed adapter card designed to link the Pamux® bus to PCI Express-compatible computers. This quick start shows you how to install the card and the PAMUX Systems SDK software that works with it.
The PCI-AC51 is a high-speed adapter card designed to link Opto 22 I/O to PCI-compatible computers for PC-based control using the Pamux protocol. This quick start shows you how to install the adapter card and the PAMUX Systems SDK that works with it.
The PCI-AC51 and PCIe-AC51 are high-speed adapter cards designed to link the Pamux® bus to PCI-compatible or PCI Express-compatible computers.
$324.00
$293.00
$408.00
$405.00
$670.00
$607.00
$717.00
