P240D4-17
P240D4-17
OBSOLETE P Model, 240 VAC, 4 Amp, DC Control Solid State Relay (SSR), Replacement Part Only
This P Model, 240 VAC, 4 Amp, DC Control Solid State Relay (SSR) should be used as a replacement part only. For new development, use the equivalent P240D4 SSR instead. The two parts are manufactured identically using the same VDE-approved optocoupler and have identical specifications.
NOTE: Specifications for P240D4-17 are identical to P240D4.
120/240 Volt Solid State Relays
MP120D2
or P120D2
MP120D4
or P120D4
MP240D2
or P240D2
MP240D4
or P240D4
MP380D4
Nominal AC Line Voltage
120
120
240
240
380
Nominal Current Rating Amps
2
4
2
4
4
1 cycle Surge (Amps) Peak
20
85
20
85
85
Nominal Signal Input
Resistance (Ohms)
1000
1000
1000
1000
1000
Signal Pick-up Voltage
3VDC***
(24V allowed)
3VDC***
(24V allowed)
3VDC***
(24V allowed)
3VDC***
(24V allowed)
3VDC***
(24V allowed)
Signal Drop-out Voltage
1 VDC
1 VDC
1 VDC
1 VDC
1 VDC
600
600
600
600
800
Maximum Output Voltage Drop
1.6 volts
1.6 volts
1.6 volts
1.6 volts
1.6 volts
Off-State Leakage mA Maximum**
5 mA
5 mA
5 mA
5 mA
5 mA
12–140
12–140
24–280
24–280
24–420
I2t Rating t=8.3 (ms)
2
30
2
30
30
Isolation Voltage
4,000 VRMS
4,000 VRMS
4,000 VRMS
4,000 VRMS
4,000 VRMS
θjc* °C/Watt
20
6.5
20
6.5
6.5
Dissipation Watts/Amp
1.2
1.2
1.2
1.2
1.2
Rating (Motor Load)
1 FLA at 120 VAC
6 LRA at 120 VAC
2.5 FLA at 240 VAC
6 LRA at 240 VAC
1 FLA at 120 VAC
15 LRA at 120 VAC
2.5 FLA at 240 VAC
15 LRA at 240 VAC
2.5 FLA at 380 VAC
15 LRA at 380 VAC
Agency Approvals UL, CSA, RoHS, CE; UKCA UL, CSA, RoHS, CE; UKCA UL, CSA, RoHS, CE; UKCA UL, CSA, RoHS, CE; UKCA UL, CSA, RoHS, CE; UKCA
Notes: θjc* = Thermal resistance junction to base. Maximum junction temperature is 110 °C.
** Operating Frequency: 25 to 65 Hz (operates at 400 Hz with 6 times the offstate leakage)
*** = P Series 32 volts maximum.
