The OptoTerminal Firmware file contains the current firmware versions for the OptoTerminal-G70 and OptoTerminal-G75 operator interfaces. See the OptoTerminal Qlarity Foundry User's Manual for firmware installation instructions.
Use this file to correct a problem that occurs when a SNAP Ultimate brain running an ioControl 6.0 or 6.1 strategy with subroutines communicates with an Opto 22 OptoTerminal. If your strategy does NOT use subroutines, you don't need to use this file.
To use this file, include it as a file that is downloaded with the ioControl strategy.
1) In ioControl's debugger, double-click on your control engine.
2) Click Download Options, and then click Add This to Files to Download After the Strategy.
3) Download the strategy to the SNAP Ultimate brain.
The OptoTerminal programming software contains the Qlarity Foundry software application, which is used to create and program the OptoTerminal-G70 and OptoTerminal-G75 operator interfaces. This complete installation includes user's guides and current OptoTerminal firmware, which can also be downloaded separately.
