GRV-OVMALC-8
GRV-OVMALC-8
$750.00 (USA and Canada only)
Analog output, 8 channels, voltage or current, chassis-powered loop
The GRV-OVMALC-8 analog output module has 8 channels, individually configurable for any one of seven voltage or current output ranges:
  • 0 to 5 VDC
  • 0 to 10 VDC
  • -5 to +5 VDC
  • -10 to +10 VDC
  • 0 to 22 mA
  • 4 to 20 mA
  • 0 to 20 mA
Each range has 4096 counts (12 bits) of resolution. See the Specifications tab for more information.
For current outputs, the GRV-OVMALC-8 also provides an isolated loop supply.
Part of the groov EPIC® system, the GRV-OVMALC-8 mounts on a groov EPIC chassis with a GRV-EPIC-PR1 processor and other analog, discrete, and serial groov I/O modules, to give you the mix of signals you need.
Features GRV-OVMALC-8
Channel-to-Channel Isolation
Watchdog Timeout Value x
Scaling x
Ramping x
Clamping x
Problem indication x
Specification GRV-OVMALC-8
Output Ranges (Resolution) Voltage
 0  to  5  VDC (1.22 mV)
 0  to  10 VDC (2.44 mV)
-5  to +5  VDC (2.44 mV)
-10 to +10 VDC (4.88 mV)
Current
0 to 22 mA (6 microamps)
4 to 20 mA (4 microamps)
0 to 20 mA (5 microamps)
Resolution Range / 4096 (12-bits)
Accuracy ± 0.1% of span
Max Current for Voltage Output 10 mA
Output impedance 280 Ohms
External current loop power N/A, internal loop power only
Maximum current loop resistance 750 Ohms
Data Refresh Time 10 ms
Problem Indication Current outputs: Open circuit / Voltage outputs: Over-current
Isolation (field-to-logic) 300 V working, 1500 V transient (1 minute)
Isolation (channel-to-channel) None
Number of Channels 8
Chassis Power Consumption 1.8 W all voltage outputs / 6.2 W all current outputs
Minimum GRV-EPIC-PR1 Firmware Version 1.0.0
Minimum PAC Project Version 10.000
Wire Size 28–14 AWG
Torque, connector screw 2.5 in-lb (0.28 N-m)
Torque, hold-down screw 3.5 in-lb (0.4 N-m)
Relative Humidity (non-condensing) 5–95%
Agency Approvals UL/cUL (Class 1 Div. 2)a; CE, ATEX (Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Warranty Lifetime
groov Analog Voltage and Current Output Module Data Sheet
groov® analog voltage and current output modules are part of Opto 22's groov EPIC® System. This document includes descriptions, specifications, and wiring and dimensional diagrams for part numbers GRV-OVMAILP-8 and GRV-OVMALC-8.
GRV-OVMALC-8 Module Firmware
This download contains current firmware for the GRV-OVMALC-8 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes document.
You can download a previous version of the firmware by clicking on these links: 1.3b1.3a1.0f
CAD Drawing: groov I/O Module
