GRV-OACS-12
GRV-OACS-12
$400.00 (USA and Canada only)
AC discrete output, 12 channels, 12-250 VAC, on/off only
The GRV-OACS-12 digital output module can switch up to 12 separate loads of 12-250 VAC. The module's 12 channels provide on/off switching only, offering a lower-cost option for projects with simple requirements.
The module provides 300 volts of transient protection for sensitive control electronics from industrial field signals. AC outputs are zero voltage turn on and zero current turn off to minimize transients during switching.
Part of the groov EPIC® system, the GRV-OACS-12 module mounts on a groov EPIC chassis with a GRV-EPIC-PR1 processor and additional discrete, analog, and serial groov I/O modules, providing the mix of signals you need at one location.
NOTE: If your application requires additional features such as pulsing and totalization, see the GRV-OAC-12 module instead.
Number of channels 12 12 12 12
Channel-to-channel isolation x x
On/off state x x x x
Output pulsing/TPO x   x
On/off totalization x   x
Problem indication x   x
Problem Indication open circuit none open circuit none
Isolation (channel-to-channel) 300 V working 300 V working NONE NONE
Minimum GRV-EPIC-PR1 Firmware Version 1.0.0 1.0.0 1.0.0 1.0.0
Agency Approvals UL/cUL (Class 1 Div. 2)a; CE, ATEX (Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Warranty Lifetime
GRV-OACS-12 Module Firmware
This download contains current firmware for the GRV-OACS-12 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes.
CAD Drawing: groov I/O Module
