GRV-OACIS-12
GRV-OACIS-12
$430.00 (USA and Canada only)
AC discrete output, 12 channels, 12-250 VAC, channel-to-channel isolation, on/off only
Part of the groov EPIC® system, the GRV-OACIS-12 digital output module switches up to 12 separate 12-250 VAC loads. The module provides on/off switching only, offering a lower-cost option for simple applications.
The GRV-OACIS-12 module provides 300 volts of transient protection for sensitive control electronics from industrial field signals. To minimize transients during switching, AC outputs are zero voltage turn on and zero current turn off.
The GRV-OACIS-12 module mounts on a groov EPIC chassis with a GRV-EPIC-PR1 processor and additional descrete, analog, and serial groov I/O modules.
NOTE: If your project requires additional features like totalizing and pulsing, see the GRV-OACI-12 module instead.
Number of channels 12 12 12 12
Channel-to-channel isolation x x
On/off state x x x x
Output pulsing/TPO x   x
On/off totalization x   x
Problem indication x   x
Problem Indication open circuit none open circuit none
Isolation (channel-to-channel) 300 V working 300 V working NONE NONE
Minimum GRV-EPIC-PR1 Firmware Version 1.0.0 1.0.0 1.0.0 1.0.0
Agency Approvals UL/cUL (Class 1 Div. 2)a; CE, ATEX (Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Warranty Lifetime
GRV-OACIS-12 Module Firmware
This download contains current firmware for the GRV-OACIS-12 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes.
CAD Drawing: groov I/O Module
