GRV-OACI-12
GRV-OACI-12
$355.00 (USA and Canada only)
AC discrete output, 12 channels, 12-250 VAC, channel-to-channel isolation
The GRV-OACI-12 digital output module can switch up to 12 separate 12-250 VAC loads. The module's 12 channels provide channel-to-channel isolation plus 300 volts of transient protection for sensitive control electronics from industrial field signals. To minimize transients during switching, AC outputs are zero voltage turn on and zero current turn off.
Part of the groov EPIC® system, the GRV-OACI-12 offers a full set of features, including:
  • On/off state
  • Output pulsing
  • On/off totalization
  • Open circuit indication
The GRV-OACI-12 module mounts on a groov EPIC chassis, with a GRV-EPIC-PR1 processor and other discrete, analog, and serial groov I/O modules, to provide the mix of signals you need at any location.
NOTE: For projects that require only on/off switching, see the GRV-OACIS-12 module, a lower-cost option.
Number of channels 12 12 12 12
Channel-to-channel isolation x x
On/off state x x x x
Output pulsing/TPO x   x
On/off totalization x   x
Problem indication x   x
Problem Indication open circuit none open circuit none
Isolation (channel-to-channel) 300 V working 300 V working NONE NONE
Minimum GRV-EPIC-PR1 Firmware Version 1.0.0 1.0.0 1.0.0 1.0.0
Agency Approvals UL/cUL(Class 1 Div. 2); CE, ATEX(Category 3, Zone 2), RoHS; DFARS; CB Scheme
Warranty Lifetime
groov® 12-250 VAC output modules are part of Opto 22's groov EPIC® System. This document includes descriptions, specifications, and wiring and dimensional diagrams for these modules.
groov I/O Modules Firmware Readme
Readme for the latest update to the groov I/O modules. Includes information on new features, enhancements, and bug fixes.
Declaration of Conformity (GRV-EPIC)
GRV-OACI-12 Module Firmware
This download contains current firmware for the GRV-OACI-12 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware readme document.
You can download the previous version of the firmware by clicking on this link: 1.3a1.0l
CAD Drawing: groov I/O Module
This ZIP file includes drawings that apply to all groov I/O modules. There are two drawings:
  • One drawing that shows the module cover in the lower position.
  • One drawing that shows the module cover in the higher position.
