GRV-OAC-12
GRV-OAC-12
$465.00 (USA and Canada only)
AC discrete output, 12 channels, 12-250 VAC
The GRV-OAC-12 digital output module can switch up to 12 separate AC loads of 12-250 VAC each. The module is part of the groov EPIC® system and provides 300 volts of transient protection for sensitive control electronics from industrial field signals. AC outputs are zero voltage turn on and zero current turn off to minimize transients during switching.
The GRV-OAC-12 offers a full set of features, including:
  • On/off state
  • Output pulsing/TPO
  • On/off totalization
  • Open circuit indication
The GRV-OAC-12 module mounts on a groov EPIC chassis with other discrete, analog, and serial groov I/O modules and a GRV-EPIC-PR1 processor.
NOTE: For projects with simple requirements, the lower-cost GRV-OACS-12 offers on and off switching only.
Number of channels 12 12 12 12
Channel-to-channel isolation x x
On/off state x x x x
Output pulsing/TPO x   x
On/off totalization x   x
Problem indication x   x
Problem Indication open circuit none open circuit none
Isolation (channel-to-channel) 300 V working 300 V working NONE NONE
Minimum GRV-EPIC-PR1 Firmware Version 1.0.0 1.0.0 1.0.0 1.0.0
Agency Approvals UL/cUL(Class 1 Div. 2)a; CE, ATEX (Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Warranty Lifetime
GRV-OAC-12 Module Firmware
This download contains current firmware for the GRV-OAC-12 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes.
You can download the previous version of the firmware by clicking on this link: 1.3c1.3b1.3a1.0l
CAD Drawing: groov I/O Module
