Specification
GRV-IV-24
GRV-IVI-12
GRV-IVIRMS-10
Input Ranges
±160.0 VDC ±80.0 VDC
±40.0 VDC ±20.0 VDC
±10.0 VDC ±5.0 VDC
±2.5 VDC ±1.25 VDC
±40.0 VDC ±20.0 VDC
±10.0 VDC ±5.0 VDC
±2.5 VDC ±1.25 VDC
300.0 V rmsAC/DC 150.0 V rms AC/DC
60.0 V rms AC/DC 30.0 V rms AC/DC
20.0 V rms AC/DC 10.0 V rms AC/DC
5.0 V rms AC/DC 1.0 V rms AC/DC
0.5 V rms AC/DC
Over-range limits
±176.0 VDC ±88.0 VDC
±44.0 VDC ±22.0 VDC
±11.0 VDC ±5.5 VDC
±2.75 VDC ±1.375 VDC
±44.0 VDC ±22.0 VDC
±11.0 VDC ±5.5 VDC
333.0 V rms AC/DC 165.0 V rms AC/DC
66.0 V rms AC/DC 33.0 V rms AC/DC
22.0 V rms AC/DC 11.0 V rms AC/DC
5.5 V rms AC/DC 1.1 V rms AC/DC
0.55 V rms AC/DC
Resolution
Range / 1,048,576 (20-bits)
Accuracy 0.1% of Range
±160 mV ±80 mV ±40 mV
±20 mV ±10 mV ±5 mV
±2.5 mV ±1.25 mV
±20 mV ±10 mV ±5 mV
±2.5 mV ±1.25 mV
N/A
Accuracy @ 50-60 Hz
N/A
N/A
±200 mV and ±0.2% of reading
Accuracy @ 60-400 Hz
N/A
N/A
±200 mV and ±0.3% of reading
Input Impedance Nominal
9.7 megohms
9.7 megohms
9.5 megohms
Input Filter
-3 dB at 46 HZ
-3 dB at 46 HZ
N/A
DC Reversal
N/A
N/A
1% of Range
Software Data Filtering:
- Simple Moving Average (SMA)
- Weighted Average
- 1 to 32 readings
- 1 to 4096
- 1 to 32 readings
- 1 to 4096
- 1 to 32 readings
- 1 to 4096
Step Input Response Time
225 ms x SMA value
(7.2 s @ 32 SMA, Default SMA = 4)
16.5 ms x SMA value
(0.53 s @ 32 SMA, Default SMA = 4)
- 250 ms x SMA value (1 s @ SMA = 4)
- 100 to 0%: 1,100 ms x SMA value (4.4 s @ SMA = 4)
Data Refresh Time
225 ms
15.5 ms
50 ms
Analog Data Filtering
-3 dB @ 2.4 Hz
-25 dB @ 60 Hz
-3 dB @ 46 Hz
-5 dB @ 60 Hz
N/A
Common Mode Rejection
> -120 dB
> -120 dB
> -120 dB
Max. Survivable Input
300 V
300 V
330 V
Max. Operating Common
Mode Voltage
250 V
250 V
300 V
Problem Indications
out of range
out of range
out of range
Isolation (field-to-logic)
300 V working,
1500 V transient (1 minute)
300 V working,
300 V working,
300 V between
channel group 0-11 & group 12-23
300 V working,
300V working,
1500 V transient
Number of Channels
24
12
10
Chassis Power Consumption
1.0 W
2.2 W
1.5 W
Minimum GRV-EPIC-PR1
Firmware Version
1.0.0
1.4.2
1.5.0
Minimum PAC Project Version
10.0000
10.2003
10.2005
Minimum Library Package for CODESYS Version
1.0.0.0
1.0.2.0
1.0.3.0
Wire Size
28-14 AWG
28-14 AWG
28-14 AWG
Torque, connector screw
2.5 in-lb (0.28 N-m)
Torque, hold-down screw
3.5 in-lb (0.4 N-m)
3.5 in-lb (0.4 N-m)
3.5 in-lb (0.4 N-m)
Temperature (operating)
-20 °C to +70 °C
-20 °C to +70 °C
-20 °C to +70 °C
Temperature (storage)
-40 °C to +85 °C
-40 °C to +85 °C
-40 °C to +85 °C
Relative Humidity
(non-condensing)
5-95%
5-95%
5-95%
UL/cUL(Class 1 Div. 2); CE, ATEX(Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Lifetime
Lifetime
Lifetime
