GRV-IVI-12
GRV-IVI-12
$1,195.00 (USA and Canada only)
Analog voltage input, 12 channels, 8 configurable input ranges from ±1.25 to ±160 V, channel-to-channel isolation
The GRV-IVI-12 analog module is part of the groov EPIC® system. Similar to the GRV-IV-24, the GRV-IVI-12 analog module can be configured for any one of the following eight input ranges on each of its 12 input channels:
  • ±160.0 VDC
  • ±80.0 VDC
  • ±40.0 VDC
  • ±20.0 VDC
  • ±10.0 VDC
  • ±5.0 VDC
  • ±2.5 VDC
  • ±1.25 VDC
The GRV-IVI-12 module mounts on a groov EPIC® chassis with a GRV-EPIC-PR1  processor and assorted discrete, analog, and serial groov I/O modules.
Features
GRV-IV-24
GRV-IVI-12
GRV-IVIRMS-10
Scaling
x
x
x
Offset and Gain
x
x
x
Minimum/Maximum Values
x
x
x
Average Filter Weight
x
x
x
Simple Moving Average
x
x
x
Analog Totalizing
x
x
x
Problem Indication
x
x
x
Specification
GRV-IV-24
GRV-IVI-12
GRV-IVIRMS-10
Input Ranges
±160.0 VDC ±80.0 VDC
±40.0 VDC ±20.0 VDC
±10.0 VDC ±5.0 VDC
±2.5 VDC ±1.25 VDC
±40.0 VDC ±20.0 VDC
±10.0 VDC ±5.0 VDC
±2.5 VDC ±1.25 VDC
300.0 V rmsAC/DC 150.0 V rms AC/DC
60.0 V rms AC/DC 30.0 V rms AC/DC
20.0 V rms AC/DC 10.0 V rms AC/DC
5.0 V rms AC/DC 1.0 V rms AC/DC
0.5 V rms AC/DC
Over-range limits
±176.0 VDC ±88.0 VDC
±44.0 VDC ±22.0 VDC
±11.0 VDC ±5.5 VDC
±2.75 VDC ±1.375 VDC
±44.0 VDC ±22.0 VDC
±11.0 VDC ±5.5 VDC
333.0 V rms AC/DC 165.0 V rms AC/DC
66.0 V rms AC/DC 33.0 V rms AC/DC
22.0 V rms AC/DC 11.0 V rms AC/DC
5.5 V rms AC/DC 1.1 V rms AC/DC
0.55 V rms AC/DC
Resolution
Range / 1,048,576 (20-bits)
Accuracy 0.1% of Range
±160 mV ±80 mV ±40 mV
±20 mV ±10 mV ±5 mV
±2.5 mV ±1.25 mV
±20 mV ±10 mV ±5 mV
±2.5 mV ±1.25 mV
N/A
Accuracy @ 50-60 Hz
N/A
N/A
±200 mV and ±0.2% of reading
Accuracy @ 60-400 Hz
N/A
N/A
±200 mV and ±0.3% of reading
Input Impedance Nominal
9.7 megohms
9.7 megohms
9.5 megohms
Input Filter
-3 dB at 46 HZ
-3 dB at 46 HZ
N/A
DC Reversal
N/A
N/A
1% of Range
Software Data Filtering:
  • Simple Moving Average (SMA)
  • Weighted Average
  • 1 to 32 readings
  • 1 to 4096
  • 1 to 32 readings
  • 1 to 4096
  • 1 to 32 readings
  • 1 to 4096
Step Input Response Time
225 ms x SMA value
(7.2 s @ 32 SMA, Default SMA = 4)
16.5 ms x SMA value
(0.53 s @ 32 SMA, Default SMA = 4)
  • 250 ms x SMA value (1 s @ SMA = 4)
  • 100 to 0%: 1,100 ms x SMA value (4.4 s @ SMA = 4)
Data Refresh Time
225 ms
15.5 ms
50 ms
Analog Data Filtering
-3 dB @ 2.4 Hz
-25 dB @ 60 Hz
-3 dB @ 46 Hz
-5 dB @ 60 Hz
N/A
Common Mode Rejection
> -120 dB
> -120 dB
> -120 dB
Max. Survivable Input
300 V
300 V
330 V
Max. Operating Common
Mode Voltage
250 V
250 V
300 V
Problem Indications
out of range
out of range
out of range
Isolation (field-to-logic)
300 V working,
1500 V transient (1 minute)
300 V working,
300 V working,
300 V between
channel group 0-11 & group 12-23
300 V working,
300V working,
1500 V transient
Number of Channels
24
12
10
Chassis Power Consumption
1.0 W
2.2 W
1.5 W
Minimum GRV-EPIC-PR1
Firmware Version
1.0.0
1.4.2
1.5.0
Minimum PAC Project Version
10.0000
10.2003
10.2005
Minimum Library Package for CODESYS Version
1.0.0.0
1.0.2.0
1.0.3.0
Wire Size
28-14 AWG
28-14 AWG
28-14 AWG
Torque, connector screw
2.5 in-lb (0.28 N-m)
Torque, hold-down screw
3.5 in-lb (0.4 N-m)
3.5 in-lb (0.4 N-m)
3.5 in-lb (0.4 N-m)
Temperature (operating)
-20 °C to +70 °C
-20 °C to +70 °C
-20 °C to +70 °C
Temperature (storage)
-40 °C to +85 °C
-40 °C to +85 °C
-40 °C to +85 °C
Relative Humidity
(non-condensing)
5-95%
5-95%
5-95%
UL/cUL(Class 1 Div. 2); CE, ATEX(Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Lifetime
Lifetime
Lifetime
groov Analog Voltage Input Module Data Sheet
groov analog voltage input modules are part of Opto 22's groov EPIC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following part numbers:
GRV-IVI-12 Module Firmware
This download contains current firmware for the GRV-IVI-12 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release  Notes document.
You can download any previous version of the firmware by clicking on the corresponding link: 1.3e1.3c1.3b
CAD Drawing: groov I/O Module
Accuracy vs Resolution
