GRV-IV-24
GRV-IV-24
$595.00 (USA and Canada only)
Analog voltage input, 24 channels, 8 configurable input ranges from ±160 VDC to ±1.25 VDC
The GRV-IV-24 analog module can be configured for any one of the following eight input ranges on each of its 24 input channels:
  • ±160.0 VDC
  • ±80.0 VDC
  • ±40.0 VDC
  • ±20.0 VDC
  • ±10.0 VDC
  • ±5.0 VDC
  • ±2.5 VDC
  • ±1.25 VDC
Note that all channels share a common reference terminal.
Part of the groov EPIC® system, the GRV-IV-24 module mounts on a groov EPIC chassis together with a GRV-EPIC-PR1 processor and other analog, discrete, and serial groov I/O modules.
Features
GRV-IV-24
GRV-IVI-12
Scaling
x
x
Offset and Gain
x
x
Minimum/Maximum Values
x
x
Average Filter Weight
x
x
Simple Moving Average
x
x
Analog Totalizing
x
x
Problem indication
x
x
Specification
GRV-IV-24
Input Ranges
±160.0 VDC, ±80.0 VDC, ±40.0 VDC, ±20.0 VDC, ±10.0 VDC, ±5.0 VDC, ±2.5 VDC, ±1.25 VDC
Over-range limits
±176.0 VDC, ±88.0 VDC, ±44.0 VDC, ±22.0 VDC, ±11.0 VDC, ±5.5 VDC, ±2.75 VDC,  ±1.375 VDC
Resolution
Range / 1,048,576 (20-bits)
Accuracy 0.1% of Range
±160 mV, ±80 mV, ±40 mV, ±20 mV, ±10 mV, ±5 mV, ±2.5 mV
Input Impedance Nominal
9.7 meghms
Input Filter
-3 dB at 460 HZ
Software Data Filtering, simple moving average (SMA) and Weighted filter
SMA: 1 to 32 Readings
Filter Weight: 1 to 4096
Input Response Time
277 ms x SMA value (8.8 s with 32 SMA)
Data Freshness / Update
277 ms
Analog Data Filtering
-3 dB @ 2.4 Hz / -25 dB @ 60 Hz
DC Common Mode Rejection
> -120 dB
AC Common Mode Rejection
> -120 dB
Max. Survivable Input
300 V
Max. Operating Common Mode Voltage
250 V
Problem Indications
out of range
Isolation (field-to-logic)
300 V working, 1500 V transient (1 minute)
300 V between zone A (ch 0-11) and zone B (ch 12-23)
Number of Channels
24
Chassis Power Consumption
1.0 W
Connector
28–14 AWG
Torque, connector screw
2.5 in-lb (0.28 N-m)
Torque, hold-down screw
3.5 in-lb (0.4 N-m)
Temperature (operating)
-20 °C to +70 °C
Temperature (storage)
-40 °C to +85 °C
Relative Humidity (non-condensing)
5–95%
UL/cUL(Class 1 Div. 2); CE, ATEX(Category 3, Zone 2), RoHS; DFARS; CB Scheme
Lifetime
groov Analog Voltage Input Module Data Sheet
The groov analog voltage input module is part of Opto 22's groov EPIC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for this module.
Declaration of Conformity (GRV-EPIC)
GRV-IV-24 Module Firmware
This download contains current firmware for the GRV-IV-24 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware readme document.
You can download the previous version of the firmware by clicking on this link: 1.3a1.0l
CAD Drawing: groov I/O Module
Accuracy vs Resolution
