GRV-IMAI-8
GRV-IMAI-8
$1,195.00 (USA and Canada only)
Analog input, 0–20 mA, isolated, field or chassis-powered loop, 8 channels
The GRV-IMAI-8 analog input module is part of the groov EPIC® system. This module provides channel-to-channel isolation on its  8 channels of analog current input with an input range of 0 to 20 mA and 4 to 20 mA. Each channel can be powered by an internally isolated loop supply or from an externally connected loop supply. Ranges are software configurable.
The GRV-IMAI-8 mounts on a groov EPIC chassis with other analog, discrete, and serial groov I/O modules and a GRV-EPIC-PR1 processor.
Features
GRV-IMA-24
GRV-IMAI-8
Scaling
x
x
Offset and Gain
x
x
Minimum/Maximum Values
x
x
Average Filter Weight
x
x
Simple Moving Average
x
x
Analog Totalizing
x
x
Quality Indicator
x
x
Specification
GRV-IMA-24
GRV-IMAI-8
Input Range (per channel)
 -20 to +20 mA, 0 to 20 mA, 4 to 20 mA
Over-range limits
 -22 mA to +22 mA
0 mA to +22 mA, 1.8 mA to 22.0 mA
Resolution
 0.02 µA (20-bits)
0.02 µA (20-bits)
Accuracy
 ± 0.1% ( ± 20 µA )
± 0.1% ( ± 20 µA )
Input Voltage Drop nominal (Impedance ± 20%)
 5.5 V nominal @ 20 mA (275 Ohms)
Input Filter (hardware)
 -3 dB at 140 Hz
-3 dB at 140 Hz
Step Input Response Time
 225 ms x SMA value (7.2 s @ 32 SMA, Default SMA = 4 )
11 ms x SMA value
(.355 s @ 32 SMA, Default SMA = 4)
Data /Refresh Time
 225 ms
11 ms
Analog Data Filtering
 -3 dB @ 2.4 Hz / -25 dB @ 60 Hz
-5 dB @ 60 Hz
Software Data Filtering:
Simple moving average (SMA)
Weighted Filter
SMA: 1 to 32 Readings
Filter Weight: 1 to 4096
SMA: 1 to 32 readings
Common Mode Rejection
 > -120 dB
 > -120 dB
Max. Survivable Input
 ± 32 V
 ± 32 V
Problem Indications
 out of range
out of range
Isolation (field-to-logic)
 300 V working, 1500 V transient (1 minute)
 300 V between group A (ch 0-11) & group B (ch 12-23)
Number of Channels
 24
 8
Chassis Power Consumption
 1.0 W
 1.4 W
Minimum GRV-EPIC-PR1 Firmware Version
 1.0.0
 1.3.0
Minimum PAC Project Version
 10.0000
 10.2000
Wire Size
 28-14 AWG
 28-14 AWG
Torque, connector screw
 2.5 in-lb (0.28 N-m)
Torque, hold-down screw
 3.5 in-lb (0.4 N-m)
 3.5 in-lb (0.4 N-m)
Temperature (operating)
 -20 °C to +70 °C
 -20 °C to +70 °C
Temperature (storage)
 -40 °C to +85 °C
 -40 °C to +85 °C
Relative Humidity (non-condensing)
 5-95%
 5-95%
 UL/cUL(Class 1 Div. 2); CE, ATEX(Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
 Lifetime
 Lifetime
groov Analog Current Input Module Data Sheet
groov analog current input modules are part of Opto 22's groov EPIC® System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following part numbers:
GRV-IMAI-8 Module Firmware
This download contains current firmware for the GRV-IMAI-8 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes document.
You can download the previous version of the firmware by clicking on this link: 1.3e1.3d1.3c
CAD Drawing: groov I/O Module
Accuracy vs Resolution
