$520.00 (USA and Canada only)
The GRV-IICTD-12 analog input module is part of the groov EPIC® system. This module collects temperature input data from any industry-standard Integrated Circuit Temperature Device (ICTD), such as the ICTD and ICTD-P3. The module has 12 channels of input. The GRV-IICTD-12 mounts on a groov EPIC chassis with other analog, discrete, and serial groov I/O modules and a GRV-EPIC-PR1 processor.
Features
GRV-IICTD-12
Scaling
x
Offset and Gain
Minimum/Maximum Values
Average Filter Weight
Simple Moving Average
Analog Totalizing
Problem indication
Specification
Input Range
-270.0 °C to 150 °C (-454.0 °F to 302 °F)
Input Range with ICTD Probe
-40.0 °C to 100 °C (-40.0 °F to 212 °F)
Input Range uA
3 to 425 µA
Over-range limits
Resolution
0.005 °C (0.0072 °F)
Accuracy with ICTD PROBE
±0.8 °C (±1.4 °F)
Input Filter
-3 dB at 460 HZ
Software Data Filtering:
SMA (simple moving average)
Weighted filter (Original)
1 to 32 Readings, moving average
1 to 4096 Filter Weight
Step Input Response Time
225 ms x SMA value (7.2 s @ 32 SMA, Default SMA = 4 )
Data Freshness
225 ms
Analog Data Filtering
-3 dB @ 2.4 Hz / -25 dB @ 60 Hz
Common Mode Rejection
> -120 dB AC/DC
Problem Indications
out of range
Isolation (field-to-logic)
300 V working, 1500 V transient (1 minute)
Number of Channels
12
Chassis Power Consumption
1.0 W
Minimum GRV-EPIC-PR1 Firmware Version
1.3.0
Wire Size
28–14 AWG
Torque, connector screw
2.5 in-lb (0.28 N-m)
Torque, hold-down screw
3.5 in-lb (0.4 N-m)
Temperature (operating)
-20 °C to +70 °C
Temperature (storage)
-40 °C to +85 °C
Relative Humidity (non-condensing)
5–95%
UL/cUL (Class 1 Div. 2)a; CE, ATEX (Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Lifetime
The groov ICTD temperature input module, part number GRV-IICTD-12, is part of Opto 22's groov EPIC® System. This document includes descriptions, specifications, and wiring and dimensional diagrams.
This document lists the latest updates to the firmware for groov I/O modules. It includes information on new features, enhancements, and bug fixes. List of groov I/O module firmware download pages Note: This document was formerly called a readme. The name was changed to more accurately describe its content.
This download contains current firmware for the GRV-IICTD-12 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes. You can download previous versions of the firmware by clicking on the corresponding link: 1.3b, 1.3a
$75.75
$110.00
$175.00
$125.00
$8.00
