GRV-IDCIFQ-12
GRV-IDCIFQ-12
$355.00 (USA and Canada only)
DC digital input, 12 channels, 2.5-30 V, channel-to-channel isolation, high speed, quadrature
The GRV-IDCIFQ-12 module is part of the groov EPIC® system. This DC digital input module senses the on or off status for 2.5–30 VDC input devices such as proximity switches, push buttons, and auxiliary contacts. The module's 12 high-speed digital input channels are capable of measuring frequencies up to 200 kHz when wired for basic counting. It provides channel-to-channel isolation. The input channels can be configured to provide up to 4 axes of quadrature input with an index signal for each axis, running at up to 50 kHz.
The GRV-IDCIFQ-12 module offers a full set of features, including:
  • On/off state
  • On/off latching
  • On/off totalization
  • Counting
  • Frequency measurement
  • Period measurement
  • Pulse measurement
  • Quadrature
The GRV-IDCIFQ-12 module mounts on a groov EPIC® chassis with a GRV-EPIC-PR1 processor and assorted discrete, analog, and serial groov I/O modules.
Feature GRV-IDC-24 GRV-IDCS-24 GRV-IDCI-12 GRV-IDCIS-12 GRV-IDCIFQ-12
Number of channels
24
24
12
12
12
Channel-to-channel isolation
x
x
x
On/off state
x
x
x
x
x
On/off latching
x
x
x
Counting
x
x
x
On/off totalization
x
x
x
x
x
x
Period measurement
x
x
x
Pulse measurement
x
x
x
Quadrature
x
Input Voltage (VDC)
15–30 VDC
15–30 VDC
10–30 VDC
10–30 VDC
2.5–30 VDC
Turn ON Characteristic
15 V, > 2 mA
15 V, > 2 mA
10 V, > 2 mA
10 V, > 2 mA
2.5 V
Turn OFF Characteristic
5 V, < 0.5 mA
5 V, < 0.5 mA
5 V, < 1.5 mA
5 V, < 1.5 mA
1.8 V
Input Impedance (± 5%)
See note 1.
See note 1.
See note 1.
See note 1.
1.1 K at 5 V, 2.2 K at 12 V, 3.5 K at 24 V
Max. Freq. (50% square wave)
1000 Hz (24 Vp-p)
1000 Hz (24 Vp-p)
1000 Hz (24 Vp-p)
1000 Hz (24 Vp-p)
Counting: 200 kHz
Quadrature: 50 kHz
IEC Input Type
Type I
Type I
Type III
Type III
N/A
Isolation (field-to-logic)
300 V working, 1500 V transient (1 minute)
None
None
300 V working
300 V working
300 V working
Number of Channels
24
24
12
12
12
Chassis Power Consumption
1.2 W
1.2 W
1.2 W
1.2 W
1.0 W
Minimum GRV-EPIC-PR1 Firmware Version
1.0.0
1.0.0
1.0.0
1.0.0
1.3.0
Minimum PAC Project Version
10.0000
10.0000
10.0000
10.0000
10.2000
Wire Size
28–14 AWG
28–14 AWG
28–14 AWG
28–14 AWG
28–14 AWG
Torque, connector screw
2.5 in-lb (0.28 N-m)
Torque, hold-down screw
3.5 in-lb (0.4 N-m)
3.5 in-lb (0.4 N-m)
3.5 in-lb (0.4 N-m)
3.5 in-lb (0.4 N-m)
3.5 in-lb (0.4 N-m)
Temperature (operating)
-20 °C to +70 °C
-20 °C to +70 °C
-20 °C to +70 °C
-20 °C to +70 °C
-20 °C to +70 °C
Temperature (storage)
-40 °C to +85 °C
-40 °C to +85 °C
-40 °C to +85 °C
-40 °C to +85 °C
-40 °C to +85 °C
Relative Humidity (non-condensing)
5–95%
5–95%
5–95%
5–95%
5–95%
UL/cUL(Class 1 Div. 2); CE, ATEX(Category 3, Zone 2), RoHS; DFARS; CB Scheme
Lifetime
Lifetime
Lifetime
Lifetime
Lifetime
groov 10–30 VDC input modules are part of Opto 22's groov EPIC® System. This document includes descriptions, specifications, and wiring and dimensional diagrams for these modules.
Declaration of Conformity (GRV-EPIC)
CAD Drawing: groov I/O Module
