GRV-IDCI-12
GRV-IDCI-12
$380.00 (USA and Canada only)
AC/DC discrete input, 12 channels, 10–30 VDC, 10–25 VAC, channel-to-channel isolation
The GRV-IDCI-12 module is part of the groov EPIC® system. This AC/DC digital input module senses the on or off status for 10–30 VDC or 10–25 VAC input devices such as proximity switches, push buttons, and auxiliary contacts. The module's 12 channels provide channel-to-channel isolation; they do not share any field signal connections inside the module.
The GRV-IDCI-12 module offers a full set of features, including:
  • On/off state
  • On/off latching
  • On/off totalization
  • Frequency measurement
  • Period measurement
  • Pulse measurement
The GRV-IDCI-12 module mounts on a groov EPIC® chassis with a GRV-EPIC-PR1 processor and assorted discrete, analog, and serial groov I/O modules.
NOTE: For projects with simple requirements, the GRV-IDCIS-12 module offers on/off sensing only and is a lower cost option.
Feature GRV-IDC-24 GRV-IDCS-24 GRV-IDCI-12 GRV-IDCIS-12 GRV-IDCIFQ-12
Number of channels
24
24
12
12
12
Channel-to-channel isolation
x
x
x
On/off state
x
x
x
x
x
On/off latching
x
x
x
Counting
x
x
x
On/off totalization
x
x
x
x
x
x
Period measurement
x
x
x
Pulse measurement
x
x
x
Quadrature
x
10–25 VAC
10–30 VDC 2.5–30 VDC
Input Impedance (± 5%) See Note 1. See Note 1. See Note 1. See Note 1. 1.1 K at 5 V,
2.2 K at 12 V,
3.5 K at 24 V
Max. On/Off Freq. (AC Input, 24 VAC, 60 Hz) N/A N/A 20 Hz N/A N/A
Agency Approvals UL/cUL(Class 1 Div. 2) (See Note 2.); CE, ATEX(Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Note 1: IEC inputs have non-linear impedance. See the tables in the data sheet for typical V-I curves.
Note 2: For use in hazardous locations, equipment must be mounted in an enclosure that meets the requirements of the National Electrical Code, ANSI/NFPA 70, and ANSI/ISA-61010-1 (82.02.01).
GRV-IDCI-12 Module Firmware
This download contains current firmware for the GRV-IDCI-12 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes.
You can download the previous version of the firmware by clicking on this link: 1.3c1.3b1.3a1.0k
CAD Drawing: groov I/O Module
