GRV-IACDCTTL-24
GRV-IACDCTTL-24
$380.00 (USA and Canada only)
AC/DC discrete input, 24 channels, 2.0-16 VAC/VDC
The GRV-IACDCTTL-24 digital input module can sense the on or off status for up to 24 AC or DC devices between 2.0 and 16 volts. Its 24 channels are not isolated from each other; all channels share a common reference terminal.
The GRV-IACDCTTL-24 module offers a full set of features:
  • On/off state
  • On/off latching
  • On/off totalization
  • Frequency measurement
  • Period measurement
  • Pulse measurement
The GRV-IACDCTTL-24 module mounts on a groov EPIC® chassis alongside a GRV-EPIC-PR1 processor and other digital, analog, and serial groov I/O modules to provide the mix of signals you need at any location.
NOTE: For projects with simple requirements, see the GRV-IACDCTTLS-24 module, which is lower cost and offers on and off sensing only.
Feature GRV-IACDCTTL-24 GRV-IACDCTTLS-24
Number of channels 24 24
Channel-to-channel isolation
On/off state x x
On/off latching x
On/off totalization x
Frequency measurement x
Period measurement x
Pulse measurement x
Specification GRV-IACDCTTL-24 GRV-IACDCTTLS-24
Input Voltage 2–16 VAC / VDC 2–16 VAC / VDC
Turn-on Voltage 2.0 VAC (Peak) / VDC 2.0 VAC (peak) / VDC
Turn-off Voltage 0.8 VAC (Peak) / VDC 0.8 VAC (Peak) / VDC
Input Impedance (±5%) 2 kOhms 2 kOhms
Max. Freq. (50% square wave 5 Vp-p) 2000 Hz N/A
IEC Input Type N/A N/A
Isolation (field-to-logic) 300 V working, 1500 V transient (1 minute) 300 V working, 1500 V transient (1 minute)
Isolation (channel-to-channel) None None
Number of Channels 24 24
Chassis Power Consumption 1.0 W 1.0 W
Wire Size 28–14 AWG 28–14 AWG
Torque, connector screw 2.5 in-lb (0.28 N-m) 2.5 in-lb (0.28 N-m)
Torque, hold-down screw 3.5 in-lb (0.4 N-m) 3.5 in-lb (0.4 N-m)
Temperature (operating) -20 °C to +70 °C -20 °C to +70 °C
Temperature (storage) -40 °C to +85 °C -40 °C to +85 °C
Relative Humidity (non-condensing) 5–95% 5–95%
Agency Approvals UL/cUL (Class 1 Div. 2)a; CE, ATEX (Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Warranty Lifetime Lifetime
groov 2–16 VAC VDC Input Modules Data Sheet
groov® 2–16 VAC/VDC input modules are part of Opto 22's groov EPIC® System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following part numbers:
GRV-IACDCTTL-24 Module Firmware
This download contains current firmware for the GRV-IADCTTL-24 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware readme document.
You can download the previous version of the firmware by clicking on this link: 1.3b1.3a1.0k
CAD Drawing: groov I/O Module
