GRV-IAC-24
GRV-IAC-24
$380.00 (USA and Canada only)
AC discrete input, 24 channels, 85-140 VAC/VDC
The GRV-IAC-24 is a groov EPIC® system AC input module that can sense the status from devices such as pumps, fans, and motors that use a 85–140 VAC/VDC signal. It can sense status from up to 24 devices and offers a full set of features, including:
  • On/off state
  • On/off latching
  • On/off totalization
  • Frequency measurement
  • Period measurement
  • Pulse measurement
The GRV-IAC-24 module mounts on a groov EPIC chassis alongside a GRV-EPIC-PR1 or GRV-EPIC-PR2 processor and other analog, discrete, and serial groov I/O modules.
NOTE: For projects with simple requirements, a lower-cost option is the GRV-IACS-24 module, which offers only on and off sensing.
Feature GRV-IAC-24 GRV-IACS-24 GRV-IACI-12 GRV-IACIS-12
Number of channels 24 24 12 12
Channel-to-channel isolation     x x
On/off state x x x x
On/off latching x   x
On/off totalization x   x
Frequency measurement x   x
Period measurement x   x
Pulse measurement x   x
Specification GRV-IAC-24 GRV-IACS-24 GRV-IACI-12 GRV-IACIS-12
Nominal Input Voltage Range (RMS) 85–140 VAC / VDC 85–140 VAC / VDC 85–140 VAC / VDC 85–140 VAC / VDC
Turn-on Voltage 85 VAC / VDC 85 VAC / VDC 85 VAC / VDC 85 VAC / VDC
Turn-off Voltage 35 VAC / VDC 35 VAC / VDC 35 VAC / VDC 35 VAC / VDC
Input Impedance (± 5%) 133 kOhms 133 kOhms 68 kOhms 68 kOhms
Operating Frequency 40 Hz to 400 Hz or DC 40 Hz to 400 Hz or DC 40 Hz to 400 Hz or DC 40 Hz to 400 Hz or DC
Isolation (channel-to-channel) NONE NONE 300 V working 300 V working
Number of Channels 24 24 12 12
Chassis Power Consumption 1.0 W 1.0 W 1.0 W 1.0 W
Agency Approvals UL/cUL(Class 1 Div. 2)a; CE, ATEX (Category 3, Zone 2); RoHS; DFARS; CB Scheme; UKCA
groov 115 VAC/VDC Input Modules Data Sheet
groov 115 VAC/VDC input modules are part of Opto 22's groov EPIC® System. They can handle input ranges from 85 VAC/VDC to 140 VAC/VDC.
This document includes descriptions, specifications, and wiring and dimensional diagrams for the following part numbers:
GRV-IAC-24 Module Firmware
This download contains current firmware for the GRV-IAC-24 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware readme document.
You can download the previous version of the firmware by clicking on this link: 1.3c1.3b1.3a1.0k
CAD Drawing: groov I/O Module
