$525.00 (USA and Canada only)
Specification
GRV-EPIC-PSAC
GRV-EPIC-PSDC
GRV-EPIC-PSPT
Max Output Power
60 W (-20 °C ≤ Ta ≤ 50 °C)
50 W (50 °C < Ta ≤ 70 °C)
50 W (-20 °C ≤ Ta ≤ 70 °C)
108 W from external 12 VDC supply,
Input Voltage Range
110 to 240 VAC nominal,
100 to 264 VAC max.
24 to 48 VDC nominal,
22 to 50 VDC max.
10 to 15 VDC
Typical Input Current (max load)
0.6 A at 115 VAC
3.5 A at 22 VDC
9 A at 12 VDC
Inrush Current
30 A at 115 VAC
2.5 I2t (A2s)
Input Frequency Range
50 Hz to 60 Hz
n/a
Power Factor
>0.98 at 115 VAC, full load
Wire size
28-12 AWG
Torque (connector screw)
4.4 in-lb
Fuse
2 A 250 V Slow
Opto 22 PN: GRV-EPIC-PSAC-FUSE
4 A 250 V Slow
Opto 22 PN: GRV-EPIC-PSDC-FUSE
10 A 125 V Fast
Opto 22 PN: GRV-EPIC-PSPT-FUSE
Operating Ambient Temperature
-20 °C to 70 °C
Altitude Temperature Derating
5 °C per 1000 m over 2000 m
MTBF (minimum, 25 °C)
650 khrs
1.9 Mhrs
4.5 Mhrs
UL/cUL(Class 1 Div. 2), CE, ATEX(Category 3, Zone 2), RoHS, DFARS; UKCA
30 months
groov EPIC® power supplies, converters, and adapters provide AC or DC power for your Opto 22 groov EPIC System. This document provides information, specifications, and dimensional diagrams for: GRV-EPIC-PSAC (AC power supply) GRV-EPIC-PSDC (DC power converter) GRV-EPIC-PSPT (power adapter)
This CAD file includes drawings in a variety of file formats (pdf, dwg, stp) that can represent any of the groov EPIC power supply models:
This ZIP file contains drawings in a variety of file formats for groov EPIC products, including the groov EPIC processor, chassis, groov I/O modules, power supplies, and more, all in one download. NOTE: This is a very large file (55+ MB) and may take awhile to download. If this file is too large or you need drawings only for a specific product, you may prefer the following:
$20.00
