B3000-B-OMUX
B3000-B-OMUX
$688.00 (USA and Canada only)
SNAP Analog/Digital Brain, Optomux Protocol
NOTE: For new systems requiring a brain that communicates serially, we recommend a SNAP PAC SB serial brain. If you're ready to modernize or need easier system integration, see the groov EPIC System. Fully compatible with SNAP PAC, groov EPIC offers secure, efficient data processing and communication for industrial internet of things applications, as well as real-time control and I/O at the edge of your network.
The B3000-B-OMUX is a drop-in replacement for a B3000 that uses the Optomux protocol. The B3000-B-OMUX is identical to the B3000-B (which uses the mistic protocol) but contains different firmware. The B3000-B-OMUX has a sticker on its side to identify it.
Power Requirements
5.0–5.2 VDC at 750 mA maximum (does not include module power requirements)
Operating Temperature
0 to 60 °C
Storage Temperature
-40 to 85 °C
Humidity
Communications Interface
RS-485, 2- or 4-wire, twisted pair(s), with shield
Data Rates
300 baud to 230.4 Kbaud
Range: Multidrop
32 stations maximum between repeaters; up to 3000 ft (914 m) between repeaters
LED indicators
SERIAL (transmit/receive), STAT (brain status), IRQ (interrupt)
Options:
Switch Selectable
Address
Baud rate
Binary/ASCII
CRC/Checksum
Agency Approvals CE, DFARS; UKCA
B3000-B Serial Brains Data Sheet
B3000-B brains are serial brains designed as drop-in replacements for the obsolete B3000. Two models are
available:
  • The B3000-B replaces a B3000 that uses the mistic protocol. This model is compatible with FactoryFloor controllers running OptoControl strategies and SNAP B-series mounting racks. The B3000-B has the same functionality as the B3000 but supports mistic only.
  • The B3000-B-OMUX replaces a B3000 that uses the Optomux protocol. This model is compatible with SNAP B-series mounting racks and contains firmware suited for an Optomux system.
The two models have identical hardware but different firmware. The B3000-B-OMUX has an identifying label on its side.
B3000-B-OMUX Firmware Readme
This Readme file lists revision changes made to the firmware used in the B3000-B-OMUX brain, a serial brain using the Optomux protocol.
B3000-B Serial Brains User's Guide
available:
The two models have identical hardware but different firmware. The B3000-B-OMUX has an identifying label on its side. This guide shows you how to configure, wire, and maintain both brains.
B3000-B-OMUX Brain Firmware
Firmware for B3000-B-OMUX brain. For details, see the firmware Readme.
