$62.50 (USA and Canada only)
480/575 Volt Solid State Relays
480D10-12
480D15-12
480D25-12
480D45-12
575D15-12
575D45-12
575Di45-12
Nominal AC Line Voltage
480
575
Nominal Current Rating (Amps)
10*
15*
25*
45*
1 cycle Surge (Amps) Peak
110
150
250
650
Nominal Signal Input Resistance (Ohms)
1000
730
Signal Pick-up Voltage
3 VDC (32V Allowed)
3VDC (32V Allowed)
Signal Drop-out Voltage
1 VDC
1200
Maximum Output Voltage Drop
3.2 volts
1.6 volts
Off-State Leakage (mA) Maximum**
11 mA
15 mA
100–530
100–600
I2t Ratingt=8.3 (ms)
50
1750
90
IsolationVoltage
4,000VRMS
θjc*** (°C/Watt)
1.2
1.3
0.67
Dissipation (Watts/Amp)
2.5
0.9
Notes: * Ambient temperature will affect the current rating. For details, see the Thermal Ratings charts in the Solid State Relays Data Sheet (form 0859). ** Operating Frequency: 25 to 65 Hz (operates at 400 Hz with 6 times the offstate leakage). ***θjc = Thermal resistance from internal junction to base. Maximum internal junction temperature is 110 °C.
A quick overview of Opto 22 solid-state relays (SSRs).
Opto 22 provides a full range of reliable solid-state relays (SSR). This data sheet includes descriptions, specifications, dimensional drawings, and application information for these parts:
This document lists all Opto 22 part numbers that have the Canadian Standards Association (CSA) approval.
This document lists all Opto 22 part numbers that have the Underwriters Laboratory (UL) approval.
$81.00
