Included software |
PAC Control™ Basic |
x |
x |
PAC Control Professional |
x |
PAC Display™ Basic |
x |
x |
PAC Display Professional |
x |
PAC Manager™ |
x |
x |
OptoOPCServer™ |
x |
OptoDataLink™ |
x |
SoftPAC™ |
x |
Control Software: PAC Control |
Compatible controllers |
groov EPIC processors |
x |
x |
SNAP PAC controllers (S-series and R-series) |
x |
x |
SoftPAC software-based controller |
x |
x |
Compatible I/O |
Built-in I/O unit (in groov EPIC and SNAP PAC R-series controllers) |
x |
x |
groov RIO modules (with groov EPIC and SNAP PAC controllers1 ) |
x |
x |
SNAP PAC brains (obsolete) |
x |
x |
G4EB2 brains (with groov EPIC and SNAP PAC) |
x |
x |
E1 and E2 brains (with groov EPIC and SNAP PAC) |
x |
x |
Serial mistic™ brains/bricks: B3000-B, B3000, SNAP-BRS, B100, B200, G4D16R, G4D32RS, G4A8R (with SNAP PAC2 ) |
x |
Network |
Controller to PC: groov EPIC and SNAP PAC—Ethernet |
x |
x |
Controller to I/O:
- groov EPIC—Ethernet only
- SNAP PAC S-series:
- Ethernet to R-series controllers and obsolete EB brains
- Serial to obsolete SB brains
- Serial to obsolete mistic brains
- SNAP PAC R-series—Ethernet only |
x
x |
Controller to third-party devices: Ethernet or serial3 |
x |
x |
Support for Ethernet link redundancy or segmented control network |
x |
(Obsolete as of 2022) Support for controller redundancy (SNAP PAC S-series only) |
x |
Main features |
Flowchart programming |
x |
x |
OptoScript programming |
x |
x |
Subroutines (debuggable) |
x |
x |
Graphical debugger |
x |
x |
Conversion utility for OptoControl 4.1 strategies |
x |
Support for serial mistic I/O units2 |
x |
Ethernet link redundancy (with S-series controllers and R-series I/O units) |
x |
Maximum charts running at once |
On groov EPIC (plus host task) |
64 |
64 |
On SoftPAC (plus host task) |
64 |
64 |
On SNAP PAC S-series (plus host task) |
32 |
32 |
On SNAP PAC R-series (plus host task) |
16 |
16 |
Proportional-integral derivative (PID) loops |
PID algorithms for Ethernet I/O units |
4 |
4 |
PID algorithm for mistic serial2 |
1 |
Loops per SNAP PAC rack-mounted controller or brain |
96 |
96 |
Loops per groov RIO module |
4 |
4 |
Loops per mistic brain/brick2 |
8 |
Graphical tuner for Ethernet PID loops |
x |
x |
Graphical tuner for mistic2 PID loops |
x |
Ethernet link redundancy |
Primary and secondary IP addresses on groov EPIC processors and SNAP PAC controllers |
x |
PAC Control commands can be used to control redundancy algorithm |
x |
Controller redundancy4
(Required hardware obsolete as of 2022)
PAC Redundancy Manager utility |
x |
Checkpoint blocks |
x |
Additional toolkits5 |
Modbus Integration Kit (serial and TCP) |
x |
x |
Controller Area Network (CAN) Integration Kit6 |
x |
x |
Other Integration Kits (BACnet, TL1, DNP3, IEC60870-5,Allen-Bradley DF1)6 |
x |
x |
HMI Software: PAC Display |
Main features |
Alarming |
x |
x |
Trending |
x |
x |
Logging |
x |
x |
Operator authentication and login |
x |
x |
3000-graphic library |
x |
x |
Additional graphics tools for PID and embedding web pages |
x |
Data logging to MySQL, Microsoft® SQL Server, and other ODBC databases |
x |
Conversion utility for OptoDisplay projects |
x |
Primary and secondary IP addresses for control engine |
x |
Primary and secondary scanner |
x |
Controllers supported |
groov EPIC processors7 |
x |
x |
x |
x |
ioProject controllers |
x |
x |
OptoControl controllers with Ethernet interface |
x |
OPC Server: OptoOPCServer8 |
OPC version |
OPC DA 2.0-compliant8 |
x |
Database Connectivity: OptoDataLink9 |
Databases supported |
Microsoft SQL Server, Microsoft Access, MySQL, and ODBC-compatible databases |
x |
PC-based Control: SoftPAC |
Compatible I/O |
groov RIO modules |
x |
x |
groov I/O (EPIC processor) |
x |
x |
SNAP PAC (R-series and EB-series) |
x |
x |
Ethernet I/O units (E1, E2, UIO, EIO) |
x |
x |
G4EB2 brains |
x |
x |
1 Requires SNAP PAC controller firmware 10.3a or higher, or groov EPIC firmware 2.0.0 or higher.
2 Requires SNAP PAC S-series controller(s).
3 On a groov EPIC, serial connections from the processor require a USB-to-serial adapter.
4 The required SNAP-PAC-ROK Redundacy Option Kit is obsolete as of 2022.
5 For more information, see the Communication Tools & Protocols for Opto 22 Products Technical Note (form 1820).
6 Not recommended for use with groov EPIC processors running PAC Control.
7 PAC Display projects can include groov EPIC systems and their groov RIO modules. PAC Display cannot run on an EPIC processor's built-in touchscreen; it runs on a Microsoft Windows PC.
8 For an OPC UA-compliant server, use a groov EPIC processor.
9 Do not use OptoDataLink with a groov EPIC processor; use its included data communication options instead. |
