KB90624
Published: March 29, 2024
Graphics may appear invisible in PAC Display Configurator
R10.5c to current (may affect other versions)
When opening an existing project in PAC Display Configurator, graphics may appear invisible. You may be able to select the graphics and see their bounding boxes, but the graphics themselves do not appear inside the window.
NOTE: This issue does not affect PAC Display Runtime.
In PAC Display Configurator:
- Open the desired project.
- Close all windows (Window > Close > Select All > OK).
- Open all windows (Windows > Open > Select All > OK).
- Save the project.
- Close PAC Display Configurator.
- Reopen the project in PAC Display Configurator to examine the windows. The affected graphics appear correctly.
